Hi all,
I moved into a house with no gas, my plan is to get the gas installed by SGN, at the same time I would like to take the opportunity of replacing the main water pipe made of lead with a MDPE pipe.
I have 2 questions:
1) I was advised to use a 25mm MDPE pipe, do stop cocks owned by the water supplier (in this case Scottish water) normally use 25mm compression fittings?
2) I am going to install a standard 25mm to 22mm compression stop cock but came across a MDPE stop cock. What is the advantage of using a MDPE stop cock knowing I will connect it to 22mm coper pipes?
Thanks!
Ant
I have 2 questions:
Thanks!
Ant
