G
Goldspoon
Just plumbed in a sink. Supplied flexis are the same both ends i.e. screw threads designed to go onto taps. Usually I have supplied them and choose to have one end with a compression fitting and olive (for fitting to the 15mm copper pipe).
So what I did was screwed the non tap end straight onto a 15mm iso valve. Obviously no olive involved and I'm not sure if this is a way to go. Water not on until tomorrow so can change in the morning to my usual method - would rather use the parts supplied if poss though. Will this be sound the way I have done it? Is there another, better way?
Thanks in advance!
Thanks in advance!
