Connecting bellbox to Galaxy G2-20
21 May 2009
Derbyshire
Hi all, very new to this forum stuff!
I have a query that i hope someone could help me with...
I have a galaxy G2-20 alarm panel and i want to connect to it, a bellbox that i've bought, but i cannot for the life of me, figure out the connections!
The bellbox has ten connections;
10 - strobe
9 - strobe
8 - tamp
7 - tamp
6 - batt (-)
5 - batt (+)
4 - siren
3 - 0v
2 - +v
1 - siren hold off
I think i may have to program the panel's hold off supply differently for this bellbox but i'm really not sure!
If anyone can advise, i'd be very grateful... :?
OK - the first 4 are the important ones...
I'm not familier with the G2-20, so I will use generic terminology which hopefully will help...
1. Connect to a permanent negative (Ov) in your panel
2. Connect to a permanent positive (12v) in your panel
3. Link inside the bellbox to terminal 1
4. This is your negative trigger - sometimes named Bell -ve (or similar) in your panel
The only bit I can't figure out is how you get your negative tamper return to the panel. My guess is that you link terminal 1 or 3 to terminal 7 and then connect terminal 8 to your panel negative return terminal.
Maybe someone else can explain that one and confirm if the other connections are correct......
I believe this bellbox (it's a chubb delta 5 - forgot to state that in original posting) has a positive trigger as opposed to a negative trigger.
Thanks for your reply. Much appreciated.
If anyone else has any input on this, i'd love to hear from you
