Got a wc pan that needs replacing as it's cracked and where it joins the cast soil socket - it's leaking too. The toilet is upstairs and the CI stack is outside - other side of wall from bathroom. The CI pipe for wc comes horizontally through wall. It's all over 60 years old.
I'm going to need to cut the CI socket off that the pan joins onto. I was planning to use a chain cutter as grinder is messy and limited access for reciprocating saw. Will old cast pipe cut successfully with a chain cutter? Or is it likely to have rusted internally and be fragile (ie. not cut cleanly)?
Also, I was planning on joining the new pan to the cast soil pipe using a McAlpine Mac-1. What will the internal surfaces of the CI pipe be like after more than 60 years? I'm thinking that if it's likely to be rough/scaled or corroded then the rubber seals on the pan connector may not seal properly inside the CI pipe.
mcalpineplumbing.com
Or would it be better to cut the CI soil pipe back a bit further and use a Fernco rubber coupling to connect a short length of pvc soil pipe between the soil pipe and pan connector?
www.thesafetysupplycompany.co.uk
Straight MACFIT WC Connector
Streamline your WC connections with the Straight Macfit WC Connector, ensuring a reliable and efficient solution for water flow.
Fernco Drain Coupling - Size 100-115 mm- [FRN-DC115]
TSSC Product Fernco Drain Coupling - Size 100-115 mm- [FRN-DC115]
