Connecting Tape Deck to Cambridge Audio Amp?
8 Nov 2006
London
Hi All
How do i connect my Eltax tape deck to an Cambridge Audio Amp?
Pics as attached.
Thank you
First connect the "PLAY(OUT)" sockets on the tape deck (in your first photo) to the "Tape In" sockets on the Amp.
Check that you can play a tape.
If that works, connect the "(IN)REC" sockets on the tape deck to .... probably "Rec Out 1" ??? on the Amp, and see if you can record anything.
Connect play out on tape Dec.
Amp is marked for tape in.
Then on amp you switch to tape so any feed in on the tape channel gets put through to speakers
