Connecting to soil
6 Dec 2006
I have a new kitchen and re-located waste pipe i want to connect to the existing house soil pipe (outside). I have dug a trench to the soil pipe which comes out about a foot higher.
1. can i connect to it from directly above, or should i run the new connection into the side of the soil pipe at the same level?
2. Should i put an inspection chamber at this junction?
3. Where the waste pipe comes out of the house to my new soil pipe should i incorporate a trap in the new soil pipe?
Thanks for all replies.
Are you aware that this work is notifiable and subject to Building Control approval?
Er, it's usually to connect into the side of a soil stack, but what do you mean by "connect to it from directly above"? :confused:
What? Are you proposing to connect a kitchen waste pipe underground? If so, then don't.
Waste from what? Whatever the answer to a trap in the soil pipe is not permissible (or sensible). I have a hunch that you're using the word "soil" when you mean something else.
Could you restate your questions and/or give your definition of the following words:
waste
junction
trap
soil
Thanks for your comments, I've called in an expert to have a look!
Just so you know what i was trying to explain;
I have a new kitchen layout including new sink/washing machine/dishwasher location which exits the building in a new area, at about 18" above the soil level.
I have the white waste pipe (about 2.5"diameter)exiting the house(not yet connected to anything) and i want it connecting to the existing underground pipework (a black fibre/composite 4" pipe).
I had provisionally dug a trench from white pipe to black pipe. I have exposed the black pipe where i want to connect. The trench is not as deep as the black pipe and i was asking whether i can drop the new pipe directly down into it or dig the trench deeper and run in to the side of the black pipe. Now i've given it some thought i'm sure it should go in the side.
Thanks for your help.
mills said:
...i was asking whether i can drop the new pipe directly down into it or dig the trench deeper and run in to the side of the black pipe.
You're not allowed to do either!
And I'm sure that it shouldn't connect to the underground drain at all.
OK. Without meaning to, I've misled you slightly. Apologies.
Revisiting the second question from your first post, it should have gone like this:
Yes. All underground runs must be roddable, and all junctions must be accessible.
Whilst I'm not aware of any specific regulation that prevents you connecting a 40mm kitchen waste to a 110mm (or 4", or whatever) underground foul drain pipe, it's not a good technical solution, IMHO.
Also, because foul drain modifications are notifiable, you can't do it without LABC approval, and I would expect a BCO to reject this idea.
So, if you have no soil stack nearby, my advice is to:
1. Consult your BCO for informal advice.
2. Follow his advice.
3. Notify LABC and get approval for what you want to do.
4. Carry out the work.
5. Get it inspected and obtain the certificate.
Thanks for your advice. At this point my questions are really to understand the process and keep the costs down by using my labour to dig the trench. I've employed a drainage company and left the tech. bit with them.
Cheers.
Probably a good call, but have you asked them to sort out the LABC approval? You would be unwise to assume that they'll do it without being asked, but they would be incompetent not to confirm with you exactly what the situation is.
