Connecting up new oven & hob.
9 Oct 2006
Norwich
Hi there,
I've nearly finished fitting my new kitchen, just waiting for a professional to fit the worktops for me :wink:
Previously we had a free standing cooker, now have a built under fan oven with a seperate ceramic hob.
The supply to the outlet is 6.0mm and the oven is already connected up.
When I connect the hob, should I be connecting to the same wall outlet, or can I connect it up through the oven (or the oven to the hob).
Looking at the wall outlet plate, I'm not sure there will be sufficient room to get both cables in there and through the cable clamp in the outlet, whereas there is room for more than 1 cable through the clamps into the back of the oven and also the clamp for the hob.
Somebody who knows more about it will probably be along in a minute, but it is not unusual to connect a single oven (if it is less than 3 KW) to the kitchen ring via a 13 Amp plug, leaving the cooker circuit for the hob only.
Thanks TicklyT.
The oven is 2.8KW and I did consider using a 13 amp socket behind the cupboard next the oven, but when everything is finished, I won't be able to get to the socket to isolate the supply to the oven if I ever need to.
Another way might be a 13A socket (unswitched) on a spur for the oven wired via an accessible switch from the kitchen ring.
I like my method. Wire a socket switched by the cooker switch. Isolation and protection. :D This can be done by means of a junction box behind the oven or if you can, in the cooker outlet plate.
