Hi, can anyone help with some advice on an induction hob:
According to the manual, before you use the hob for the first time you need to select the connection current and walks you through a step-by-step instruction of how to select the current you need.
My issue is knowing the correct connection current to select from the list in the manual:
20A
16A
13A
10A
The cooker circuit is on a 32A MCB and I've been told that the total load of the hob is 7.2kw, can anyone advise which is the correct current to select?
Many thanks
Howie
20A
16A
13A
10A
Many thanks
Howie
