- Joined
- 6 Jan 2019
- Messages
- 7
- Reaction score
- 0
- Country
Hello all. I want to fit a cat flap to my conservatory door. I'm planning on replacing the glass with UPVC, within which I will cut out the required hole to fit the flap. I took the small bottom glass section out today and measured it with two tape measures and a steel ruler. The thickness was showing as 27mm. I was quite surprised to find when looking online that neither UPVC nor replacement glass come in 27mm - 28 seems to be the mark (26 is available but seems quite rare). I read a couple of people who had the same experience, but it was with UPVC and the explanation offered up was it might have shrunk. I can't see this piece of glass shrinking, and it seems tight with no play when replaced. The cat flap is around £20, the UPVC around £60 which I will have to cut for size. I don't want to buy a 28mm UPVC panel and find it won't go in - my two tape measures might be slightly out, but surely my steel ruler isn't? Admittedly my eyesight isn't what it used to be but I'm quite confident it's 27 - what am I to do?
