Conservatory floor
5 Jun 2011
Cheshire
Hi guys I'm planning to take up the flooring in my brothers conservatory as there is no insulation below. He currently had laminate 9mm, underlay 2mm then 18mms chipboard. He would like a bit more clearance below his door so can anyone recommend a decorative flooring like laminate that could be fixed to the joists which requires no maintenance.
Thanks in advance guys
I assume that as you've only 13mm above the chipboard, that you're intending to take up the chipboard, fit the insulation, and then refit something to the joists so that you've increased the clearance under the door. Taking the laminate off will warm things in the first place, and you could look to fit T&G wood or something similar to the joists, and then varnish them.
Yes pal your assumptions are correct. That is the plan but he doesn't want to have to keep treating the floor so was looking for alternatives for him. I suggested hardwood flooring but like I said he doesn't want to have to maintain it so looking for something along the lines of laminate that I could fix directly to the joists.
Laminate floors always float, so no good there I'm afraid. What sort of treatment does he think he needs to do to a wooden floor though.
Yeah I get you about the laminate but wondered if there was a similar product to fix to joists.
Just the obvious one of sanding and varnishing every time it gets scratched.
A laminate floor will get scratched and damaged just as easily as a wooden floor will, but with laminate, you have to remove the whole floor. A real hard wood floor is a lot harder, and can sometimes be polished locally rather than the whole floor. He can't have everything I'm afraid, and a wooden floor will be much warmer than a laminate floor. You can insulate under the laminate, and you'll still find the floors cold, and the room taakes longer to heat.
