Conservatory oversite plans
2 Dec 2009
Essex
Hi All,
I just came up the following spec for the oversite of my 6x3m conservatory
I'm looking to install a wet heating system with a 65mm thermal screed before tiling / laminating
Does it look spot on or am i being too cautious with the thickness of the insulation and multiple vapor layers?
Would Polystyrene be a cheaper as efficient option and do away with the extra two layers of polythene? - my concerns here would also be laying a screed over polystyrene vs celotex in terms of strengh
100mm MOT Type 1
Sand blinding - 25mm-50mm
DPM - 1200g turned up into DPC
100mm concrete slab (with rebar)
1200g vapor polythene sheet (to stop moitsure from cement attacking celotex foam)
75mm Celotex/Kingspan or 125mm polystyrene insulation
1200g vapor polythene sheet (to stop screed from attacking celotex foil)
ProWarm / Polypipe Wet Heating system
65mm thermal screed (top of screed level with house DPC)
thanks
Andrew
I would check with your LABC to see what they will allow. Building regulations stipulate that conservatories have heating systems that are "independent"
Some LABC's say independent means just that; in that it is not connected to the main house heating system in any way, shape or form. Others seem to accept it being linked to the boiler, as long as it has separate time control and thermostat.
Thanks Stem, I'm not so worried about the heating system, I will be going independent and underfloor regardless, im keeping outside of the LABC on most accounts with the overall build.
Andrew
