Hi all,
I did post this elsewhere on this site but maybe here is a better place.
I’m building a lean to conservatory that is 5330mm wide x 2710mm deep & to date I’ve done the foundations, brickwork, all windows etc & now need to make it watertight with a roof.
I have all of the wood to create the rafters & hopefully this is where you guys come in to help me achieve the next step. To give you an idea of what it looks like etc there are a couple of pics here:
As you’ll see roof height is tight but there is enough room there to create the drop we need.
Had a quick nose on the net & found a website http://onlinepolycarbonate.co.uk & saw what they had to try & visualise what I need.
So far I reckon we need this lot:
4 x 16mm polycarbonate Roofing sheets length 3000mm x width 1050, tint: clear
1 x 16mm polycarbonate Roofing sheets length 3000mm x width 14000, tint: clear
2 x Anti dust breather tape (10 metres length) 16mm thickness
7 x 2.1 mtr PVC Sheet Closure Trim (for top & bottom sheets & the one exposed side)
6 x snap Fix Rafter Supported Glazing bar, white 3mtr lengths
So do you reckon the above is what I need, or is there something I've missed? Price wise the website above was about £420 delivered, is that good or is there somewhere else I should be looking?
Thanks for your help,
Russ
Russ
