Conservatroy glass roof reseal.
Discussion in 'Windows and Doors' started by peweuk, 18 Feb 2021.
  1. peweuk
    peweuk
    23 May 2008
    165
    Thanks Received:
    Wales
    Country:
    We have a lean to conservatory with a glass roof consisting of 7 double glazed glass panels fitted at no more than 20 degrees of horizontal.
    The panel in the middle has stated to leak water at the wall end. This only happens in heavy long rain showers and when there is a wind. From outside I can see a small gap in the rubber seal which needs attention - a few minute job.
    A local company quoted me a couple of hundred pounds to fix it (saying the cost was due to a need for scaffolding etc under health and safety).
    I then saw a contractor working on installing a glass lean to canopy next door merrily walking up their glass panel to bash down the lead flashing, and he said that the glass taking weight is not the problem, it is normally the problem of slipping due to the angle of the glass that would stop him walking on a conservatory roof.
    So now I am thinking, would it be safe to crawl up my roof and fix the leak rather than pay a large sum to a contractor.
    What do you guys think?
  2. Sponsored Links
  3. ronniecabers
    ronniecabers
    14 Nov 2014
    959
    Thanks Received:
    188
    Country:
    Depends on the pitch of your roof to be honest. Above about 10 degrees and you run a real risk of falling off and hurting yourself. As the guy said the roof will take the weight, the roof bars will be designed for ' snow loads' ( usually 2 ton) but without proper support you are really running an issue of slipping... If you can use boards and say a box scaffold and set it up so it can't move then possibly... We use a proper conservatory roof ladder than sits on the floor and rafters
  4. peweuk
    peweuk
    23 May 2008
    165
    Thanks Received:
    Wales
    Country:
    Thanks,
    The pitch of the roof is approx 6 degrees (according to my level) and the glass panels are 2.1 m long x .7m wide
    I had come up with the idea of using 'crawlboard' 1.8m x .5m made from 5mm hardboard. I hope this will spread the 'point' load of feet/knees and with the rough side of the hardboard face up this will minimise foot slip, and if the smooth side which is facing down is covered with a slip resistant material (the rubber mesh sheet) which would minimise slip potential on the glass.
    For the amount of time I'll be on the roof, and with the minimal amount of movement necessary, hopefully this will work.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
