I am considering options for replacement for an old boiler. And before I call someone in to give advice, i've been searching the internet for options.
The boiler is an Ideal Mexico floor standing boiler in a downstairs room "boiler room", about 15 radiators (x2 in conservatory), vented system, hot water cylinder, coldwater tank (large) and central heating expansation tank (smaller one) in a upstairs room (laundry room). System is a honeywell Y plan installed around 1994 and in good overall condition.
The laundry room is about the size of a box room though the cylinders etc take up a lot of space. This room is located at the mid-point of the bungalow and reasonably close to downstairs bathroom and next to upstairs bathroom. The boiler room is downstairs next to the downstairs bathroom.
Everything works well apart from hot water taking a long time to reach tap in the kitchen due to a long run (takes over 60 seconds). The boiler is 36.6kw and the hot water cylinder is 170l. The hotwater cylinder and header tank currently supply a power shower which is not working (motor dead). All central heating pipework to radiators is 10mm and in good condition (installed 1994). The boiler room is reasonably large, is installed on the outside wall (which has a drain on the other side) and also has gas services coming into it (as well as electric).
My requirements of sorts are that the replacement would free up the space in the laundry room by doing away with all or some of the cylinder/tanks.
A "nice to have" would be hot water at mains pressure (or better than current gravity fed system).
A really nice to have would be the possibility for secondary heating compatibility such as solar or wood burner etc.
I'm not too keen on combi boilers as i like having a hot water cylinder and with two small nippers they have regular baths.
I've seen a boiler type which has a cylinder incorporated into it - would this allow me to basically house everything in the downstairs boiler room which is next to the downstairs bathroom?
The only issue I can imagine (in my uneducated in these matters mind) is the already slow hot tap in the kitchen taking even longer, as the hot water would be coming from further away..
Sorry for the long post, I thought providing all the info might be helpful.
Mike
Mike
