You can run all the cooking appliances on the new cable.
There is no such thing as "MCBOs".Hi all
I've two consumer units, crabtrees circa 1990s with MCBOs, one CU for lights and the second for sockets. The only RCDs (RCBO?) are one for garage, and the other for a shower. Am looking at having an induction hob fitted, so adding extra 6mm cable/circuit, so electrician is involved already.
Total mcbo/rcbo in use is 19, but a new one will need to be added, with a separate CU for RCD for the new circuit according to the electrician.
I'm thinking of biting the bullet and getting them upgraded.
Been quoted £1.3k by the electrician, whom I've used before.
It's a lot of money but in theory would make the installation safer is that right? Any other benefits?
What should I be looking for in terms of questions. The quote doesn't include what manufacturer for example and I'd want a quality brand. Any advice appreciated.
You can run all the cooking appliances on the new cable.![]()
People that accept jobs like this one: https://careers.thecollege.co.uk/vacancy/foundation-lecturer-561043.htmlWho is teaching these kids this absolute tripe?
Quite so - although, as below, only (hopefully) in relation to a pretty small proportion of electricians.I'm gobsmacked how uneducated these sparks are.
Quite possibly people who themselves were 'taught' in the same way - i.e. a self-perpetuating problem (and the electrical trade by no means has a monopoly on this problem).Who is teaching these kids this absolute tripe?
Apprentice teens, who have their earphones shoehorned in their ears for the whole day end up being uneducated while obtaining a qualification.I'm gobsmacked how uneducated these sparks are.
An isolator' is essentially just a switch. What is your problem and why do you feel the need for both?The electrician has put wiring in place for an extractor fan for the kitchen which will go in the ceiling void at a later date, just getting the circuit in place, switched from a wall switch. I asked where the isolator is, and he said it's on the wall, the switch. So no isolator.
Extractor fans usually don't have any dedicated switch (just come on with the lights) - which is why some people think it's a good idea to have an isolator (switch) just for the fan.
Fair enough - but I imagine that none of those have a switch which switches off (only) the fan, do they? However ...Every other extractor fan in the house has a dedicated isolator switch as well as the activator switch ...
OK. That's a fairly unusual situation (with the switch remote from the fan) - so, yes, I agree that in that case it would be a good idea to have an isolator fairly close to the location of the fan (for the reason you give)..... In the case of the kitchen fan, it'll be serviced from the eaves, and with the switch on the kitchen wall downstairs, I rather think an isolator would be a good idea next to the fan in case someone switches it on downstairs whilst it's being worked on.
