I want to take a cable off to my garden shed from my consumer unit in the garage. The problem is that the consumer unit is an old model and I have had to buy a retrofit kit from MK Electric so that I can fit an MCB type that is currently available.
Fitting the retrofit kit means that I have to go into the CU and extend the busbar. I don't have much experience of working inside CU's. Is it the case that if I turn off the main trip the entire busbar will be dead and safe to work on? I have a DVM, so I am not about to put myself in harms way without checking what is there voltage-wise, it's just that I dont want to commit to turning off the power (with all the ramifications with regard to resetting clocks inside the house) only to find that there is something else that needs to be done for which I am not prepared.
Secondly, since I will be installing a small CU in my new shed/cabin, do even need an MCB for this link in the main CU in the garage? I would guess so in case of shorting/damage to the SWA going out to the shed?
