- Joined
- 29 May 2007
- Messages
- 20
- Reaction score
- 0
- Country
I wish to replace my old fuse board, which is mounted in my garage about 10 feet above ground level, with a new CU.
I want to position the new CU at a more reasonable and reachable height.
Unfortunately, this would necessitate lengthening the cables. Would it be OK to solder on additional cable and insulate with heat shrink, or would it be preferable to use junction boxes?
Is there any minimum height below which a CU should not be positioned?
All suggestions greatlfully received.
