Hi all ... I'm looking to replace my current distribution setup as it is rather antiquated and bulky (have electro-magnetic RCCB's always been such huge ugly looking things)
Property is overhead wired TT on a 60A service fuse with a Crabtree 60A RCCB hanging (literally) off 16mm2 tails about 2m from the meter. 16mm2 tails to an old 4 way CU a few inches away with 4 wired fuses 5A, 15A, 30A and 45A.
The property has benefitted (in building terms) from a previous extension whose circuits are supplied by another separate 2 way CU (30A + 5A) connected via 6mm2 to (you've probably guessed) the 45A fuse on the 4way CU.
A new kitchen is going in and, as the main 4 way CU is high on the current kitchen wall and looks like something you'd expect to see on the wall of an Athens holiday flat, I'm taking the opportunity to replace the lot with a single split load unit and run some new circuits around the place whilst I have access (kitchen ring, radials for new ovens, freezer and smoke alarm etc) and split the current circuits across the two busbars as appropriate.
I'm planning for a 100A DP incomer, 2 separate busbars protected by a 100A 100mA time delay RCD and an 80A 30mA RCD respectively ... I will need 6 ways on each bus to allow for futureproofing.
Any advice on make/model for the CU together with suppliers would be greatly appreciated.
Thanks in advance
Thanks in advance
