Im in the process of installing an 8.5kw shower into the bathroom of a small flat
The current set-up in the cu is as follows;
100A main switch
63A 30mA rcd side of cu;
30A running cooker and 13A socket
30A ring running 3 x double socket, 2 x single socket
30A ring running 2 x double
30A running 1 kitchen extractor & 2 heaters (heaters permanently out of use)
16A running socket for washing m/c, dryer and microwave
non rcd side of cu;
15A running water heater
5A running lights
5A running lights
If I install 40A mcb on rcd side of cu will it overload?
i dont use too much at the same time, worst case scenario shower, cooker, kettle, washing m/c, dryer, 3-4 sockets and a few lights at once
Or would it be better to install the mcb on the non rcd side of the cu run it to a separate rcd then to the 45A switch?
Any help would be greatly appreciated
Thanx
100A main switch
non rcd side of cu;
5A running lights
5A running lights
Thanx
