Consumer Unit Upgrade required for new kitchen?
6 Apr 2012
Blackpool
I am getting quotes for a new kitchen. One firm say that I need to upgrade my electric consumer unit so that the kitchen is on a separate circuit. Is this correct? The current CU has isolators for upstairs sockets, downstairs sockets, lights and shower.
Alio123
New work needs to be to 17th ed 2008. Rcd protection, bonding for gas and water services.
Either the existing board is pre 17th or is too full to take the new circuits. Post a picture and let's see if it can be updated or if the suggestion to provide a small board just for the kitchen is the best way.
Picture of board, main intake and meter and any grouping of grn yellow earth by the intake please.
Given the potential loads I believe it is always a good idea to have the kitchen sockets as a separate circuit - but it is not an absolute requirement. Your oven/hob circuit will also need to be included as well.
A lot will depend on your current consumer unit. When a new circuit or extension to the circuit in the kitchen is made you will need to have it RCD protected.
If your current CU does not have RCD protection then an additional say 4 way RCD (RCBO) protected consumer unit can be added just for the kitchen. (leaving the your current CU still in place)
No, but not a bad idea, but this does not mean you require a new consumer unit. A little more detail will be required
What type of consumer unit is it?
I assume that with you stating consumer unit, it has MCBs rather than fuses.
A picture would help if unsure.
