So were you saying that the forensic engineers employed to establish the causes of fires identified the causes
In most cases they did establish the origin of the fire and the source of ignition. Scientist is more accurate than engineer in this type of investigation where chemistry is frequently involved.
and then decided that nothing should be done to address those causes?
I assume you are pushing the loose terminal as the main cause of fires in consumer units. They probably are the most likely cause but not the only one.
Quite a lot of effort was put into reducing the risk of a loose terminal. One outcome of that effort was the adoption of maintainance free terminals. Good idea if it was reliable when applied to terminals in consumer units. For some reason which I have yet to discover they were not considered reliable enough for use in consumer units. One Fire Brigade ( not London ) did suggest that by law electrical installations should be examined at least once every 5 years for loose terminals. The overall concensus was that loose terminals cannot be prevented.
