We obviously don't have the full facts, but it is our understanding that it was the LFB that essentially brought about this change. It has even been suggested to us (by someone who had reason to have some inside information) that JPEL/64 were essentially 'bullied' by the LFB to make this change to BS7671, under threat of resort to political/legal approaches if they did not comply - the implication perhaps being that JPEL/64 were far from convinced that the change was appropriate/needed.I do feel the London Fire Brigade are being given a bad deal over this. They are not the only fire brigade to have raised concerns about plastic consumer units but they seem to be the only brigade betting the "blame".
Exactly my point - so it is only a justifiable change if one is pretty sure that that 'slight increase' is balanced by at least an equal 'slight decrease' in risks due to CU-related fires.Of course the risk of electric shock is increased slightly if the consumer unit case is Earthed metal.
Definitely. To have an unearthed exposed-conductive part would certainly increase risks, as well as being non-compliant with regs.( Does it have to be Earthed ).
As I said, they don't seem to have 'thought it out' all that well. If they truly believe that a significant number of house fires result from a plastic CU case catching on fire as a result of something within it initiating a fire, they should at least have demanded some requirement for 'fire containment' (which, after all, is a major consideration in terms of fire safety requirements) - but they didn't.I am sure that the Fire Investigation Officers of the brigades advocating a change had thought this out and based on their decades of experience of investigating the causes of fires decided that inflamable consumer units should not be installed.
In any event, even if they had required 'fire containment', as was often said in discussions when this change was first proposed, if the problem is that components within a CU are catching on fire, then one really ought to try to find a way of addressing that problem, rather than taking measures to slow the spread of such fires. If an aircraft engine developed a reputation for exploding in flight, sending shrapnel through the fuselage, one hopes that measures would be taking to reduce the risk of such explosions, rather than strengthening the 'containment' around the engine to reduce the risk of shrapnel escaping and doing harm!
Kind Regards, John
