contrails (chemtrails)
atmospheric conditions such as -
Barometric air pressure.
This is elementary stuff. You weren’t serious about this surely….
Well then you need to read it all to understand the difference between a con and a chemtrail. In a nutshell one is short in length and dissipates within 5 mins and the other goes from horizon to horizon and does not dissipate but instead it stays for hours upon hours and spreads ot joining all the others until the once blue sky at 11am by 4pm is now just a white milky blanket vastly reducing the suns power. Look up once in a while and you will see for yourself.
We are not talking about making clouds in this case - its keeping them away. Its long been talked about but labelled as conspiracy - as per standard Just found this
Professional conspiracy theorist believes in a conspiracy theory. Shocking stuff.
I'm not watching it but does he recommend large fans to keep the clouds away or is there some sort of very fine net?
Why contrails form on some day but not on others? I got chat gpt to write it out cos it's faster at typing than me: Because the air up there isn’t always right for them.
Contrails form when hot, moist jet exhaust hits very cold, humid air at cruising altitude. If those conditions aren’t met, you get nothing visible.
The main factors:
1. Humidity at altitude If the upper air is dry, the exhaust vapour evaporates quickly, so no trail.
2. Temperature It needs to be cold enough (usually below about −40°C). Warmer air means no condensation.
3. Atmospheric layers Planes can fly through invisible “patches” of suitable air. That’s why one aircraft leaves a trail and another nearby doesn’t.
4. Persistence Sometimes contrails form but vanish instantly, so you never notice them. On humid days they linger and spread into cirrus-like clouds.
So “no contrails day” just means the sky is too dry or slightly too warm at cruising altitude, not that planes have taken the day off.
The main factors:
All very convincing then ask it why - chemtrails do not form at night.
Bit of a case of "supporting your conspiracy theory with your questions" there. :rolleyes:
How do you know that contrails don't form at night?
Contrails do but I have never seen chemtrails at night., remember they are the ones that go from horizon to horizon stay for hours and slowly spread out untill you a milky sky covering the sun.
So the reason you don't see them at night is there is no sun they want to cover up
So they might be there, but you can't see them? :giggle:
Definitely not there at night.
Russell's teapot.
Can you prove that they are there in the day? Can you take a photo of one, with a well-known landmark in the foreground, your little finger pointing at it, and give us the time and location of your photo?
Can you prove that they are absent at night? A simple, "you can't see them at night" will not suffice.
And can you prove that the chemtrails that you see are not contrails?
