- Joined
- 16 Nov 2004
- Messages
- 53
- Reaction score
- 0
- Country
Hi I am considering getting some quotes to change to a combi to free up cylinder space (storage area) to change into a small en-suite.
My current Glowworm Spacesaver 50 has separate CH and Cyllinder flows and returns.
The CH return goes through a pump but the Cylinder return does not..
My question is: If the central heating flow and return is attached to the new combi with it's own internal pump, will the hot be able to pass through the pump that is no longer needed upstairs or will that block the flow.
Will the pump need to be cut out or can it just allow flow when it is no longer being powered.
I am not concerned about the cyllinder flow as it is separate piping and therfore will no longer be needed with a new system. Its just the central heating I am concerned about.
Many thanks,
Liam Caswell
Many thanks,
Liam Caswell
