converting 2-gang sockets to a 1gang fused spur
12 Jun 2011
My mum has a Telecare system which monitors water/smoke/gas etc. Unfortunately, she doesn't like leaving things plugged in overnight and insits in unplugging it. As she has Alzheimers she forgets the importance of the unit.
I want to convert the existing double-gang 13A sockets to a single gang fused un-switched connection unit.
At the moment, I am thinking of using a double-gang blanking plate with a cutout to enble me to have the flush single-gang mounted on it. The spur would be nut-bolted and glued to the blanking plate to ensure it is secure.
Is this ok? Is there a better way
Are you sure the Telecare unit does not have a wall wart transformer?
This would mean you cannot cut it off and hardwire it into a spur.
If it is a wall wart transformer, perhaps it and a socket can be fitted in a plastic enclosure.
