We are doing a loft conversion at the mo and I need to deal with the plumbing, house is about 2 years old.
CH is currently open vented and the fe tank needs to be removed/moved, it cannot be put up high, so will need to be floor level.
We want to fit 2 rads, ideally the best way forward is to convert to a sealed system.
I can't see a problem here, I can fit an expansion vessel and PRV, filling loop etc in the airing cupboard on the 1st floor for example, trouble with this is the airing cupboard is in the middle of the house and need to run the vent for the PRV.
Can the PRV and expansion vessel be anywhere on the system? Ie in a new cupboard on the attic level on the new leg of the heating circuit?
Otherwise I will have to leave the system as is, move the tank and install electric heating.
Thanks in advance.
Thanks in advance.
