COOKER CUT-OUT TRIPPED - CAN I TEST SENSOR?:
Discussion in 'Appliances' started by RONCHAM, 19 Nov 2015.
  1. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    The thermal cut-out tripped on my fan-assisted double oven cooker. It turned out the element had also failed - although I thought the cut-out would be designed to trip before this happened?
    What would be the likely sequence of events to cause both these things to occur? Would it be the thermostat heat sensor failed first? - and is there any way to test it?
    Could I (very briefly!!) bypass the cut-out to at least find out if the element and fan work or is there a safer way to check?
    I'd appreciate any advice.
    Regards.
  2. flameport
    flameport
    10 Mar 2007
    10,095
    Thanks Received:
    2,037
    Poole, Dorset
    Country:
    Likely - element fails internally, shorts to the metal outer covering causing a substantial fault current which destroys the thermal cutout.
    Cutout and element can be tested using any multimeter set to continuity. If there is continuity between the two terminals then they probably work, if none then they definitely do not.
  3. Sponsored Links
  4. conny
    conny
    30 Jun 2008
    14,274
    Thanks Received:
    834
    Suffolk
    Country:
    Continuity between terminals is not an indication it is working.
    You also have to test if there is a short to earth. If there is then you have a potentially dangerous situation if you turn the appliance on, especially if you have by-passed the thermal sensor. It is there for a reason and omitting it from the circuit is highly unadvisable.
  5. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    Thanks for all the advice and the safety warning which I will pass on to my son. I must admit I assumed the thermal cut-out was purely to guard against an overheating situation but I now appreciate the result of a substantial fault current.
    I did read elsewhere that a functioning cut-out usually - but not always - shows continuity. My cooker has two ovens and two cut-outs - the one in the working oven does have continuity, the other does not, which suggests it has definitely failed.
    Can the thermostat heat sensor be safely tested, either in place or if removed? I'm thinking that (if removed) it could be heated in some way whilst continuity is monitored?
    Regards.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
