I like your thinking! Very heavy weight, but if you can collect it may be cheaper
Plastic so about 8 Kg
Or
http://www.polypipe.com/housing/abo.../polypipe-soil-160mm-3m-plain-ended-pipe-grey
Gross Weight Kg: 7.095
Something must have blocked the duct then, or it got damaged when that work was done. If it was all working fine 3 months ago, something sudden must have happened.My ceiling was only boarded and plastered 3 months ago.
Well what happened in the last 3 months to reduce the efficiency?I think the current duct is intact as I can feel a reasonable amount of air when the extractor is switched on. My issue was the lack of efficiency and I wonder if that can be helped by replacing the hood with one which has a much higher extraction rate.
