    Dismiss Notice
Cooker hood connect via 3 pin plug?
Discussion in 'Electrics UK' started by diyplumber1980, 4 Oct 2012.
  1. diyplumber1980
    diyplumber1980
    3 Feb 2012
    195
    Thanks Received:
    2
    Birmingham
    Country:
    Hi
    I am installing a cooker hood into my kitchen but as I am not a qualified electrician, I have decided to use a 3 pin plug for the power supply, as opposed to connecting it directly to the mains via a fused spur.
    However I have a couple of questions i'm unsure off.
    Firstly the cable is two core and is too short to reach the power socket by about 50mm. I was thinking of purchasing a new 2 core cable of the correct length. Would it simply be a case of attaching a 3 pin plug to the new cable, and connect the other end to the relevant connectors on the cooker hood?
    Also, the instructions state in bold, several times, "Do NOT connect to earth" and "this item must NOT be earthed". Why is this? Ive never seen this before on electric products.
    Many thanks in advance
  2. Sponsored Links
  3. ericmark
    ericmark
    27 Jan 2008
    16,872
    Thanks Received:
    1,534
    Llanfair Caereinion, Nr Welshpool
    Country:
    Clearly Class II or double insulated so does not require an earth. Fixed appliances I am sure come under Part P and require notification so really you need a scheme member electrician to do the work.
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Where is the socket?
    How naff is a cable trailing from the hood to the socket going to look?
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
