    Dismiss Notice
cooker hood connection F/S or plug?
Discussion in 'Electrics UK' started by Forsh, 18 Jun 2014.
  1. Forsh
    Forsh
    10 Jul 2007
    57
    Thanks Received:
    Country:
    I have a spur to where the cooker hood (Stainless chimney type) is going, Any preferences on whether to connect the cooker hood via plug and socket or hard wired into a fused spur? (hidden behind chimney)
  2. Sponsored Links
  3. ekmdgrf
    ekmdgrf
    13 Jan 2012
    640
    Thanks Received:
    60
    Blackpool
    Country:
    I would personally use a FCU, unless you're planning on moving the extractor around the house?
  4. EFLImpudence
    EFLImpudence
    7 Jul 2010
    34,672
    Thanks Received:
    3,849
    Retired to:
    Country:
    Portugal
    So would I but it doesn't matter.
  5. Forsh
    Forsh
    10 Jul 2007
    57
    Thanks Received:
    Country:
    Thanks guys
    My instinct was FCU but it just seams easier to fix the socket before the kitchen goes in and once every thing is installed just plug the hood into into a socket without reaching over and into the hood to hard wire
  6. JohnW2
    JohnW2
    28 Jan 2011
    45,046
    Thanks Received:
    2,875
    Buckinghamshire
    Country:
    True, but even if it were a socket it would have to be reasonably 'accessible' (for inspection and testing), so it shouldn't be too much of a challenge to connect the hood to an FCU in the same place.
    Kind Regards, John
  7. mikeyd
    mikeyd
    17 Jul 2007
    784
    Thanks Received:
    75
    Country:
    Have you considered putting the FCU next to whatever it is you are connecting the spur from? And then use a flex outlet behind the chimney.
    I was advised to do that by my electrician when we did our kitchen.
    Ours is next to a double socket and the hob switch and it doesn't look out of place. I never turn it off but if in the event of something ever bursting into flames in that area, I know I can isolate the extractor and the hob without having to reach above the hob.
  8. EFLImpudence
    EFLImpudence
    7 Jul 2010
    34,672
    Thanks Received:
    3,849
    Retired to:
    Country:
    Portugal
    That's why I like all cooking appliances and hoods controlled by the cooker switch.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
