Cooker Hood Lights
15 Jul 2009
Norfolk
I have a particularly strange one with my cooker hood where only one of the lights work.
It's strange because I know the transformer inside is working because the lights are in parallel and the other light works.
I also know it is not the bulb because I have tested it (and it is ok) and I have swapped them and it does light up.
I have had the holder out a couple of times to take a closer look and occasionally when you put it back in it works for a couple of minutes or until you switch it off and then on again.
Does anyone have any ideas?
The holder will require replacing as its damaged.
Regards,
DS
