Anyway, stepping away from theoretical physics for a moment, I do like to soak my sun hat in water, put it in the freezer for a while, then put it on my head...
Window amplifying the heat was never the issue.Going back to the original argument the issue and argument was more to do with the impact of windows
No. You tried and failed to show that insulated homes would overheat because they are insulated.Going back to the original argument the issue and argument was more to do with the impact of windows, which most people would want in their home.
But it isn’t.Window amplifying the heat was never the issue.
Harry B claimed that an insulated wall would 'eventually or inevitably' allow the heat of the sun to pass through.
This is nonsense.
No the link was to introduce you to the concept of over heating.No. You trued and failed to show that insulated homes would overheat because they are insulated.
This was shown to be nonsense, even your own link said so.
Waffle. It does not happen.But it isn’t.
All the time there is a temperature difference heat will move from one to the other according to the thermal resistance of the wall.
Which showed you were wrongNo the link was to introduce you to the concept of over heating.
Still wrongThe fact remains that if the heat can get in, it will stay there longer than a less well insulated home, due to thermal resistance.
Only in theory.If it’s cooler outside than inside. The transfer will happen quicker with a high U value.
Again you show a lack of understanding of the basics. I would ridicule you for it as is customary, but in an attempt to be less of an a***hole to less intelligent beings. I will simply point you here:Waffle. It does not happen.
Yep, and Professor Lomas says you are lying again....No the link was to introduce you to the concept of over heating.
Oh good grief. Here we go it’s post-repeat-loop again.Yep, and Professor Lomas says you are lying again....
Does insulation make your house hotter?
"Insulating homes has very little, if any, impact on the risk of overheating," said Professor Kevin Lomas from Loughborough University, who led the largest national study so far into overheating in homes.
Insulation can even help keep your home cool, because most types - certainly external wall and likely also cavity wall - will stop your home from getting as hot in the first place.
Other energy efficiency measures work both ways too: insulating pipes saves energy in winter by preventing heat from leaking - and so helping keep your home cool in summer.
The exception when it comes to insulation is if you have it on the inside of your wall, which can create a "small additional risk" of overheating by one degree Celsius or so, but only if your home isn't well ventilated anyway, explained Prof Lomas
No I'm not.Again you show a lack of understanding of the basics.
Correct.Which works both ways i. e. heating and cooling.
And, in typical time frames ( the day - night cycle in general), the gradient will not be one - way nor steep enough for long enough to actually matter.
This is nonsense.
