copper manifold
18 Apr 2009
Manchester
does anyone know where i could aquire a 50 mm copper manifold. The actual manifold supplies 10 apartments situated in a multi storey building. It tee's off the main service pipe to a stop cock and then tee's off to 22mm to each apartment. the problem i have is the stem tee'ing off from the manifold is leeking from the soldered joint and i am looking at the worst scenario should resoldering not stop the leak
Would be alot easier to braze it IMHO, oxy acetylene and some copper phosperous rods (spelling) will do the trick and cheaper
Edit, i thought he meant the branch of the 54 had split, Solder will do the trick
You can't really buy them pre made,most are made on site with pulled tees and brazed up.
thanks for your reply, i would appreciate a bit of information regarding the procedure and the tools required should i need them.
Brazing a pulled T is not something for the inexperienced. You'd bodge it up on a first attempt.
Rothenberger and ITE amongst others make the tools required and are very expensive. Expanders are usually required also.
Along with the oxy/acety gear and a set of each of the above up to about 35 mm will set you back at least £1100.
Page 8 ..........
http://www.rothenberger-usa.com/fil...atalog_2010/Section_1_-_Expanding_bending.pdf
You can also get endfeed 54mm fittings. Brazing is a piece of p155. Hire a set and have a little practice. 1 hr or so tops and youl be away.
The cost of a 54x54x22 is ridiculous.
Then it's the trouble of getting it right. Normally wed use a length of 54 with pulled tees.costs a 10th of using fittings.
