N
noonespecial
Softus said:I would say you are right for water pipework and DIYers. They do the job, are not that difficult to install and safer than gas torch. They are more expensive and bulkier. BUT I READ HIS POST THAT HE IS PROPOSING TO INSTALL GAS PIPEWORK - If it is just one intermediate compression joint on gas then fine. Re-reading the post the guy does not make it clear if it is water or gas.Well, lots of DIYers do, and what on earth is wrong with that?noonespecial said:You don't use compression fittings in lieu of getting the correct pipework for the job.
Really? Why not? Perhaps you don't use it, but that doesn't make it wrong, so why do you imply that there is a general rule when there's no such thing? Perhaps to maintain some ridiculous clique of which you think you are a part?.noonespecial said:...PTFE And you don't use that in compression joints
Well I have to hold my hands up to your practical experience on making joints as I do not install them and have really very little experience in doing so. I know a lot of plumbers use PTFE tape on the screwed sections and jointing compound and also PTFE tape on the olive rings. But that all contravenes manufacturers recommendations and also anyway the joints are designed to rely on a mechanical metal to metal contact. I know tape and compound can overcome some minor leakage problems. But I have investigated quite a few severe water damage cases and seen probably hundreds of minor water leaks which has been due to excessive PTFE tape being used (not all by DIYers) and also unfortunately one death from LPG which was done by the same unfortunate DIYer. AS a result of my experiences no plumber that I employ will use PTFE tape or jointing compound on compression joints. And really it is not a problem.
OK if it is water BUT AS I SAID ABOVE I READ THE POST THAT IT IS GAS HE IS PROPOSING TO INSTALL.I disagree - the guy is willing to learn, has come to the right place (although receive many unhelpful replies), and, with some experimentation, there's no reason why he can't make a start. We all began somewhere...noonespecial said:I think you have too much to learn before you should attempt to install pipework.
Above very long winded so to summerise I would say:
If it is water pipework guy is doing then fine and I agree there is no technical reason why he cannot use compression fittings. PTFE tape should not be used on the joints.
IF IT IS GAS PIPEWORK - no not until he knows what he is doing, has adequate experience and is competent.
