Copper Push Fit
17 Oct 2013
Derbyshire
I used one of the above today for the first time as space was very tight. The fitting was a straight connector on copper pipe.
I'm worried that there seems quite a bit of play in the joint, similar to an unsoldered end feed. Is this normal?
The pipes are square and fully inserted as per the instructions. There are no leaks as yet and I have put pipe clips either side which has firmed it up.
4 Oct 2012
East Renfrewshire
It's the rubber seal that makes it water tight and the grab ring to hold it, that will be where you will probably be feeling the 'flex'. You'll have seen the teeth of the grab ring, there is always a little flex in those teeth.
No water, no problem :mrgreen:
17 Oct 2013
Derbyshire
Thanks Madrab,
I didn't know what to expect as I usually use end feed or compression. In fact, we used to use two lengths of copper with an end feed joint as a clothes line prop. Probably best not to try that with push fit.
