Corded drill - different to other posts
  • Thread starter Thread starter imamartian
  • Start date Start date
I
imamartian
I have a dewalt cordless which i use lots and love to bits... and i have a cheap but marvelous SDS drill... but my B&D corded drill has given up the ghost.... so i'm buying a new one (it's only role probably will to drill holes in masonary where i don't want to run down the battery on my cordless) - but of all the qualities of a new drill which should i focus on:
1. wattage? for example 750W to 1080W does this translate to brute power?
2. single speed/2-speed/variable speed? seeing as this drill will probably on be for drilling holes
3. 13mm/16mm chuck - what;s it matter?
4. keyed chuck - am i bothered?
Your opinions are very welcome
I'm puzzled to know why you need a corded drill for masonry if you already have an SDS drill (unless the SDS is a cordless, you don't say).
The power of the drill you choose will be governed by the maximum diameter you expect to drill in a given material. Input power is not the same as output (which is always less); presumably the ratio of input to output power varies from one manufacturer to another. Generally speaking the greater the power, the heavier and more cumbersome the tool.
I'd choose a variable speed drill, as there will be occasions when you need to start slowly when drilling something delicate. You do need slow and fast speeds anyway for different diameters and materials.
Most jobs need no more than a 13mm chuck, which will take all kinds of bits (blacksmith drills, hole saws, cone cutters, spade bits etc.) which cut much larger diameters.
Most good quality drills come with keyless chucks nowadays. I don't know of any advantage in having a keyed chuck.
But of all you want to do is to drill holes in masonry, unless you're doing core drilling you need an SDS drill.
thanks for the reply xerxes. Very helpful.
My SDS drill is one of those huge Ferm rotary hammer drills and is a bit cumbersome for most DIY jobs - i use it for breaking concrete usually. Plus it doesn't fit into my drill press thing.
in that case get a light sds one. ive got a hitachi one, cost about £95 and its served me well. i have a corded hammer drill. it gathers dust in the garage. its ryobi. i rate it as pants to ****e
i'm looking on page 840 of the screwfix catalogue....cheap and cheerful is what i'm after
...i'm buying a new one (it's only role probably will to drill holes in masonary...) - but of all the qualities of a new drill which should i focus on:
Not one of those attributes is relevant.
Buy SDS+, and pay enough for one to last as long as you need it to last.
IF you want cheap & cheerful then Argos is the place to go :D
Cant get much cheaper than the challenge extreme 1050w - it does the job, is light weight, and you can throw it away when the job is done, or keep it till the next one.
I have been using mine on my 1850 stone walled house and its not failed on anything yet.
SDS is fine but when my long drill bits are not SDS I'm hesitant to go buy all new ones just for SDS (SDS drills are usually very short).
(Well he did say cheap & cheerful) :wink:
The OP is not asking for an SDS drill.
All the SDS small diameter drill bits I have are short, you can only go in so far because the shank is a lot wider.
A real pain when trying to hang stuff that uses thin but long screws.
You can get longer SDS drills but why buy new ones if you already have perfectly adequate ones.
_____________
If it hurts, then don't do it.
The OP already has an SDS+ drill and SDS+ bits.
get a normal chuck for it and then there is no problem. best of both worlds
The OP has said that his SDS drill is big & heavy & would like an ordinary drill as well.
As the OP's old drill has died I think its safe to assume that the OP also has ordinary bits.
As much as you guys really like SDS drills, they have their place as well as ordinary chucked drills having their place too.
correct.
it's required to fill the gap between my dewalt 14.4v cordless, and my Ferm rotary hammer drill thing - easier up a ladder, or using sanding discs, or fitting in my drill press, or just more convenient around the house.
Don't be silly - he said no such thing. He said that it's likely to be exclusively for masonry.
It's never safe to assume anything.
You guys? The last time I checked there was only one of me. :?
Notwithstanding that, ordinary chucked drills have no place in masonry drilling.
