As per the title, is it possible to core drill into the side of a below-ground drainage gully?
I have for some reason, a drainage gully sat just inside the outside wall of a lean-to / conservatory and a drainage channel on the opposite side (the outside) of the wall. The latter though, does not go anywhere. The rainwater does feed via a pipe, through the wall and into the gully. Assuming any of it does not get blocked and then floods the whole area.
As such, surface rainwater backs-up and then floods under the door and into the conservatory area, draining into the inside gully.
Needless to say, this is not ideal and in fact, does not work.
I wish to cut through from the external channel, into the side wall of the gully. Is it possible, or will it just shatter the clay gully?
