BobProperty, I'm not sure why you've invented some new words to replace those in the SI, but yours are actually wrong, viz:BobProperty said:Could the powers here pin a suitable note at the top of the plumbing/heating forum to the effect of the following:
This is humourously ambiguous, as per the old joke based on the London Underground direction: "Dogs must be carried". For example, one interpretation (a pedant would say the only interpretation) of your sentence is that competent persons must spend every available minute of their lives carrying out gas work.BobProperty said:Gas work must be carried out by competent persons.
Actually not true. According to the wording of the SI, You can do gas work for someone else, as long as it is a favour and not part of a business activity.BobProperty said:If you do any gas work for anyone you have to be registered with CORGI.
Misleading - this implies that there is something to "get away with". However, no law would be broken.BobProperty said:If you do your own gas work in your own home and nothing goes wrong, you will get away with it (except for * below)
You're making quite a few claims here - do you have some reason for believing all this? For example, are you versed in the relevant case law and thereby rich in examples of precedent?BobProperty said:If it goes wrong you will have to get someone to put it right and / or your gas will be cut off.
You may be charged under Health and Safety rules. You will not get away in court by claiming competence unless you are registered with CORGI as that is the de facto definition of being competent.
Your insurer will not be paying out for any damage caused.
I can see that you were really on a roll by this point - did you seriously imagine the moderator making a sticky topic out of this alarmist claptrap?BobProperty said:* When House Information Packs for selling houses come in, or if anyone spots it before hand, you will have a problem selling your house. Expect either several hundred if not thousands being knocked off its value or having to pay out the same to prove that it's OK before you sell it.
