hi,im having a problem with measurments for a corner base cupboard,the brochere says 1000 unit but the measurements are width 1131,where is this measured?.i need a 1000 unit with one door and one blocked ,but i cant understand this ,any help appreciated,thanks
You need to leave a space at the end of the 1000 unit then when you butt up the other (600) unit against it you will be left with enough space for a 500 door.
what 600 unit is that,sorry im so thick but the picture just looks like a normal straight 1000 unit,its only when i saw the lengh measurement i thought there must be something wrong .if you could explain to me as if i dont know anything about diy(which i dont ),id be very gratefall.
