    Dismiss Notice
Correct fixing for heavy mirror
Discussion in 'Tools and Materials' started by rossj81, 27 Sep 2020.
  1. rossj81
    rossj81
    13 Nov 2019
    60
    Thanks Received:
    16
    Warwickshire
    Country:
    I want to hang a mirror on a wall. The mirror is 1800x600 / 6'x2' landscape, so short and wide, but quite heavy 24 kg/53 lbs. The wall is plasterboard on brick.
    I'm worried about putting that weight on plasterboard, so I was planning on drilling straight through into the brick. The problem is the plasterboard is 80 mm / 3" away from the brick so first I'll need to find really long screws, and then there will be a long protruding portion that's unsupported.
    I could screw into the stud but there aren't any noggins at the height I want, so it's going to be a challenge using the vertical studs and still centring the mirror on the wall.
    Any ideas?
  2. foxhole
    foxhole
    14 Mar 2006
    17,511
    Thanks Received:
    2,008
    Kent
    Country:
    150-160mm screw length , bit of tubing to use as a spacer thru plasterboard cut you size.
    Should only need a couple of these.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. Astra99
    Astra99
    1 Feb 2011
    890
    Thanks Received:
    143
    Gloucestershire
    Country:
    For that sort of weight, I would be inclined to use at least a No. 10 (5mm) screw or even an No. 12 (6mm).
    • Thanks Thanks x 1
  5. rossj81
    rossj81
    13 Nov 2019
    60
    Thanks Received:
    16
    Warwickshire
    Country:
    Thanks. Would these do? 7.5x180 CSK concrete. What sort of tubing do you suggest?
  6. Sponsored Links
  7. foxhole
    foxhole
    14 Mar 2006
    17,511
    Thanks Received:
    2,008
    Kent
    Country:
    If you use concrete screws you wont need any tube they are strong enough alone.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
