A crimping tool for use with red, yellow and blue insulated crimp terminals. Simply place the connector to be crimped in the appropriate die in the jaws and squeeze the handles together until the tool re-opens. A ratchet prevents the tool opening until the crimp is complete. A latch is provided so that the tool can be opened manually, after the ratchet has engaged, and before the crimp is complete if necessary.
