    Dismiss Notice
Correct Size Air Vent Cover - Millimetres too Big.
Discussion in 'Plumbing and Central Heating' started by DIYamTrying, 17 Sep 2021.
  1. DIYamTrying
    DIYamTrying
    21 Mar 2021
    28
    Thanks Received:
    Country:
    https://www.screwfix.com/p/manrose-cowl-vent-white-125mm/54366#_=p
    Bought this product, but the round collar does not fit inside the tube/flue. Sizewize, the collar is exactly the same as the flue so it's millimetres too big to connect. The flue has been in the wall about 15 years. It's a different manufacturer but I threw the old cover away because I thought I had the right product.
    Any ideas how I can sort this. 5 inch open hole in my flank wall now :)
  2. Sponsored Links
  3. magicmushroom666
    magicmushroom666
    11 Jan 2010
    299
    Thanks Received:
    56
    Essex
    Country:
    A straight coupler piece should be able to fit over the existing pipe, and therefore over the cowl as well?
  4. pcaouolte
    pcaouolte
    15 Nov 2012
    316
    Thanks Received:
    80
    Lincolnshire
    Country:
  5. Tigercubrider
    Tigercubrider
    22 Jul 2016
    4,533
    Thanks Received:
    735
    Country:
    If you can find a small piece of pipe the same diameter, cut a slice 25-50mm off and remove a section of the pipe about 5mm along it's "length"
    It will glue/friction fit and allow same size connection,
    Or just cut off the back of the wall plate and screw it to the wall
  6. RandomGrinch
    RandomGrinch
    15 Jun 2021
    767
    Thanks Received:
    151
    South Wales
    Country:
    Sorry, silly question!
    I just wanted to check that this was a cowl for an air vent, and not an appliance flue? :)
  7. DIYamTrying
    DIYamTrying
    21 Mar 2021
    28
    Thanks Received:
    Country:
  8. Sponsored Links
Loading...
Share This Page
