Correct Size Air Vent Cover - Millimetres too Big.
21 Mar 2021
https://www.screwfix.com/p/manrose-cowl-vent-white-125mm/54366#_=p
Bought this product, but the round collar does not fit inside the tube/flue. Sizewize, the collar is exactly the same as the flue so it's millimetres too big to connect. The flue has been in the wall about 15 years. It's a different manufacturer but I threw the old cover away because I thought I had the right product.
Any ideas how I can sort this. 5 inch open hole in my flank wall now :-)
A straight coupler piece should be able to fit over the existing pipe, and therefore over the cowl as well?
If you can find a small piece of pipe the same diameter, cut a slice 25-50mm off and remove a section of the pipe about 5mm along it's "length"
It will glue/friction fit and allow same size connection,
Or just cut off the back of the wall plate and screw it to the wall
Sorry, silly question!
I just wanted to check that this was a cowl for an air vent, and not an appliance flue? :)
