corrugated plastic roofing sheets
13 Dec 2010
Nottingham
The last time I used these I remember they were a pain to cut and fit around the waste pipe. I am using them again on my new house and wondered if anyone had any tips?
Mini angle drinder cuts through them easily, or a reciprocating saw, although for use of the latter, its reccommended that you secure the sheet to minimise vibration, or it should split/crack.
I use a jigsaw with a hacksaw (24tpi) blade. It helps if the plastic is warm (normal indoor room temperature) as it gets brittle and can shatter if too cold.
