Couple of problems popped up, everytime XP starts up scandisk trys to check one of my partitions but quits & boots into XP & secondly the recycle bin is permanently full & when I try to empty it, I get " are you sure you want to delete WINDOWS?" but recycle bin is empty when I open it up & I created a blank text document & then deleted it but that didn`t show up either. And now theres some folders that I can`t access on the partition that scandisk checks at startup because windows tells me that they`re corrupted. Now maybe I did a bad thing but I took both drives out of my old PC & put them into the new one & I changed the IDE driver to the standard one so XP would boot.
Also on the partition with the corrupted folders, several documents have appeared but the names of them are just meaningless characters & they won`t delete and this drive had two partitions with ME on one & pictures & stuff on the other but ME corrupted & wouldn`t boot so I deleted that partition.
Is the drive failing and can I recover my documents?
