    Dismiss Notice
Cost of fitting one radiator.
Discussion in 'Plumbing and Central Heating' started by amfisted, 6 Aug 2020.
  1. bennymultifinish
    bennymultifinish
    21 Apr 2020
    2,000
    Thanks Received:
    299
    Country:
    i wasnt touting for work. just thought i may be able to recommend someone if you were closer
    • Like Like x 1
  2. Sponsored Links
  3. Heating one2one LIVE
    31 Mar 2009
    280
    Thanks Received:
    41
    London
    Country:
    £80 for combi boiler drain down in London.
    £100 with a full drain with tanks in loft etc... (plus cost for valves if required)?
    • Like Like x 1
  4. amfisted
    amfisted
    28 Mar 2011
    780
    Thanks Received:
    13
    Flintshire
    Country:
    Understood.
    As it happens there's been no response to my approaches to local gas fitters/ plumbers thus far. So either they're too busy, they're on holiday, or the job is considered too small to be worth their time. Looks like BG are my only option.
  5. Ihavenojob
    Ihavenojob
    7 Jan 2010
    7,481
    Thanks Received:
    1,206
    Dystopia
    Country:
    How much does it cost to run your present heater? How long will £600 worth of gas last ?
  6. amfisted
    amfisted
    28 Mar 2011
    780
    Thanks Received:
    13
    Flintshire
    Country:
    I know....its either give the money to BG to pay for gas used by the wall heater, or give it to them to pay for the rad. The 600 quid, if used to pay for gas, would probably last longer than we're likely to stay in this house.
    On the face of it a no brainer, and yet I like the idea of running the heating in the front room with the rest of the system. .
  7. ianmcd
    ianmcd
    15 Aug 2010
    17,053
    Thanks Received:
    6,475
    Lanarkshire
    Country:
    Go to your local plumbers merchants and ask if they could recommend anyone to do your job
    • Like Like x 2
  8. Ihavenojob
    Ihavenojob
    7 Jan 2010
    7,481
    Thanks Received:
    1,206
    Dystopia
    Country:
    Agreed, and with the new scheme coming in you may get a grant for any work.
    • Like Like x 1
  9. amfisted
    amfisted
    28 Mar 2011
    780
    Thanks Received:
    13
    Flintshire
    Country:
    That's a good idea. I'll decide over the weekend whether to spend the money on the rad, or whether to put it towards my daughter's house-buying fund and use the gas wall heater more often. Its a journey, is this DIY thing.
    • Like Like x 1
  10. Sponsored Links
  11. amfisted
    amfisted
    28 Mar 2011
    780
    Thanks Received:
    13
    Flintshire
    Country:
    Good point. I'll make the relevant enquiries when the scheme materialises.
  12. amfisted
    amfisted
    28 Mar 2011
    780
    Thanks Received:
    13
    Flintshire
    Country:
    Well, I got the job done at just over half the cost quoted by BG. It was a local fitter, ironically recommended by a BG chap who did other work for me.
    The pipework from the loft to the rads drops down the corner angles of the rooms because we have concrete floors. He started by drilling through the wall of the lounge to take the pipework through a fitted wardrobe and to the wall where the radiator was to be fitted. However, because the spare bedroom is a former garage and corner of the room is slightly offset from the corresponding corner in the main building, on his first attempt the drill bit ended up in fresh air, and went straight through the external gas pipe. He repaired that right away, obviously.
    Only other problem was the appearance of two holes in our 2 year old carpet where he dropped some hot solder, but being in a corner it'll be hidden under furniture anyhow. He was very apologetic when I pointed this out, and offered me a free boiler service to compensate, but we have ours done by BG so I declined. Notwithstanding the above we're fairly satisfied with the job, and thanks again for advice provided.
  13. Mottie
    Mottie
    27 Feb 2017
    9,287
    Thanks Received:
    1,128
    Essexshire
    Country:
    And he was only half the price of others...:whistle:
    • Like Like x 2
  14. HERTS P&D
    HERTS P&D
    9 Apr 2010
    10,492
    Thanks Received:
    1,555
    Hertfordshire
    Country:
    Should of gone with BG, you would of got a new carpet and compensation.
    Andy
  15. Nige F
    Nige F
    28 Jun 2005
    20,642
    Thanks Received:
    1,613
    Country:
    But they'd have sold you a new boiler:unsure:
  16. durhamplumber
    durhamplumber
    23 May 2010
    11,401
    Thanks Received:
    482
    Durham
    Country:
    Indeed .Quite an accurate rule of thumb!
Loading...
Share This Page
