Cost of mains to garage
1 Feb 2005
Tyne and Wear
Could anyone tell me generally how much it would cost to run mains electric to a garage. It would start in loft, suspende outside to top of and through garage then down inside. Another route is from loft, down outside wall, under block paving through then up inside garage wall. The garage is 11 feet away from the house with about 30 feet of cable. Would the former be lower 100s and latter be in the upper £100s?
A bungalow?
How long is the overall length, what type of equipment are you supplying in terms of power rating.
You'll be needing one of these.
images
I would but before i did that i thought i'd ask on here 1st. To get an idea Before I get any eager lectricians drooling over the job with their toolboxes and quoting god knows what.
Actually alarm, now you mention it.. No. Just the garage door, with either the lawn mower, OR a hand drill OR a 900 watt angle grinder not all going at the same time as i'm not an octopuss :-)
No xmas lights, fridges, flood lights, fairground rides, or football stadiums.
