Could battery be flat
28 Jul 2005
Bristol
Hi All,
Second question of the day.
I bought a new 12V 7Ah battery for my burglar alarm today and fitted it in.
I was presuming that if I then turned the power off to simulate a power cut then the battery would keep things going. But no, sure enough the external sounder started.
The battery I bought is the re-chargeable type so could it be flat. If so how do I charge it?
The panel should charge it up unless the battery charging circuit is U/S or the battery fuse has popped.
How many volts are there across the battery when measured with a digital volt meter? iirc should be around 14v.
If that is fine give it a day or so for the battery to take a charge and then try again.
With the battery disconnected, what voltage to you get at the battery connections in the panel?
Most batteries come with a good charge in them.
I haven't got a meter to measure the voltage unfortunately.
Is it designed to charge up itself?
