Cove-ert problem
24 Oct 2012
Cornwall
So, they've put up the coving and there were a few irregularities with adjoining pieces.
They used filler and I sanded the join. However, the coving seems to be made of paper on a thin layer of card over plaster!
Now I have exposed the card with my sanding.
How should I proceed? I need to sand the joins otherwise they will look very poor. do I need to prep the "cardboard" in any special way before painting?
Cheers.
Gardz all the coving.
Just seals it including sanding damage.
Use a wide blade, plastic or metal and smooth over any damaged surfaces or joints.
240 grade sand.
Fill again if needed.
Spot prime filler with gardz.
Emulsion.
That's how I do it now.
Few years ago is mistcoat cove.
Fill
Sand
Spot mistcoat filler.
Some call the filling blade a busker.
I used a 150mm scraper or something similar like a spatz to fill
