Crack in Bathroom wall
28 Apr 2007
Hi
I have a crack that has appeared in the bathroom over the last year. On the outside it follows the pointing up from above the back door to below the bath room window. In the Bathroom it appears behind the radiator at floor level and goes straight up to below the window. On the inside I scaped the crack and it appears to be about an average of 3/4 mm and ruins across some of the brease blocks.
Is this anything to worry about ?
Nigel
look down near the door ...........leaking drain :?: causing slight settling :?:
Hi
One thing that has changed is that I found that my rain water was runniong stright in to the group, no proper soak away and it would have been coming out in the ground below the crack. I have now corrected this getting rid of the water correctly, could this have cause change that might have caused the crack ?
Nigel
OH Yus........impersonating Churchill dog :wink: that`s most likey why
